Product integration
I'm thinking about moving away from CD's to the world of streaming.
My current setup is Beosound 9000 to which Beolab 8000 is connected. Beomaster 7000 with Beogram 7000 is connected and played thru Beosound 9000. Next to that stays not connected to anything Beovision 11.
My plan is to buy Beosound moment and connect it somehow to my current setup so I can use speakers with 9000/7000 & Moment.
Would anyone be able to advice how to link it together?
thx M
Connect BeoLab to Moment and BeoLink Converter NL/ML to BeoSound 9000..
Connect a Chromecast audio to your Besound 9000 and keep your setup as it is. Then use a ipad to control the music.
You never know when B&O stops supporting the streaming software that you get with the unit you buy.
Agree with Leo completely. It happened with the BS5 and Spotify.
The chromecast is an excellent device in my opinion.
SOunds like an option but I'd like to stay within B&O solution.
With streaming I meant streaming from local server not Dezeer/ Spotify etc.
Interesting - how's connected Converter & 9000 ? I'm asking as I need to have also Beomaster 7000 hooked to 9000 to be able to play vinyls
Hi Marek,
For simplicity (and to keep the 7000 working without needing major re-wiring), I would suggest keeping the speakers connected to the Beosound 9000 as at present.  You can then link either a Moment or a Chromecast Audio to the Aux socket of the 9000 as outlined below:-
Moment cable: link
Chromecast Audio cable:
Hi Steve,
if I keep 8000 speakers connected to 9000 wouldn’t it be problem that Aux on 9000 is already occupied by cable connecting Beo7000 (with cable I bought from you - as many other cables haha) ?
thx
m
Hi Marek,
No problem!  You can use an Aux Splitter to share the Aux socket between the Beogram 7000 and the new music streamer without affecting the speaker connections:-
