[View:http://archivedforum2.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.00.68.35/B_2600_O.zip]
I have a strange problem with the Avant in combination with the convertor ML/NL. I have a B&O connect option disabled under product integration and can't enable it anymore.
Details of configuration and issue can be found in the attachement. All tips are appreciated.
Kind regards.
