Product Configuration Guide
I have just been sent the newest version of the Product Configuration Guide! Only having a Mac, I cannot use this but I have put it on site! Try here - remember once you download it to change the extension pdf to exe - I cannot put program files on the site so I have changed the exe to pdf to fool the system! You need to change it back and it will work! let me know if much has changed!!
BeoVision 8, BeoVision 9, BeoSystem 3,
first changes i noticed in the PCG.
Just noticed that it shows BeoVision 8 in 26" with and without ML
and in 32" with and without ML.
I was under the impression that only the 26" had a version without ML.
Sorry to sound really thick, but at what point do I change the file name to exe?
Andy T.
Be aware that it sometimes can be a little flaky! I have had several goes in the past to get it to load - probably better with XP.
No idea! 😂 Let us know!!
VMWare Fusion should work, as should Bootcamp. I've had success with the former, running Windows XP Professional
Try as I may, I can't get the PCG sorted!!!!
I have downloaded the newest Adobe Reader but when I download the PCG it does not have .pdf on the end of the file name, so how can I change it to .exe? Really frustrated now.
