Problems with sound options on PS3
I have problems getting my PS3 working with my Beovision 7 32".
It`s connected ;
Pictures via a HDMI - DVI cable and that´s fine.
Sound is thought Optical and the via a converter into the digital input on the TV.
I have no problems when playing PS3/Blue Ray films, but when I try to play PS2 or CD I can´t get any sound. Somebody who has any idea which settings I should change?
Johan
It`s connected ;
Johan
Hi Johan. Welcome to Beoworld.
I have the same problem, but I have a BV3. I can't play estereo sound, for exemple a CD, click of XMB,...
I did a test: I tried a digital coaxial with other dvd player, without optical-coaxial converter. I put a CD into, and i got the same problem: No sound. However, i can only get DTS and DD to work. That was the ultimate test. The surround module is the problem, which doesn't allowe play pcm stereo through digital coaxial.
I just called B&O.
you need to connect analog sound to BV7 with RCA cables use AV4...
Really, that’s not good; don’t want to connect a third cable to the PS3, any possibility to get it work with optical??
If you use HDMI-HDMI on the PS3 their is no problems with the sound, the sound via HDMI is also digital???
Beovision 7 32" does not support stereo digital sound! - Analogue is the only way.
Mark
And analog is the best way, because then it plays in pro logic...
