Problems with software-update at beovision 11
Fair point. It was a guess because of the remote.was there ever a ML version of the BV11?? We bought one really early and it was our first NL tv. And this BV11 came with a Beo4. Later on one could switch sw wise to a BR1.
There never was a ML version of the BV11.
Together with the V1 they were the first NL products (including the Beosystem 4).
Just as the Avant 1 Gen they were IR based - and therefore were initially controlled by the Beo4 (navi version).
The first Beoremote Ones were entirely IR based.
You could/can choose in the settings which remote, you want to use, but basicly they both work similar.
With the introduction of the Avant 2nd Gen (the Android based version) and the Horizon came the BT based Beoremote One (which also includes the IR part for backwards compatibility).
Hi Rob,
I’ll give that a whirl when I’m home from holiday. Thank you for the information and I’m sure I’m not the only one who would appreciate being able to get BBC radio stations again.
Thanks Rob that worked a treat. Please can other members who have had this problem note that this solves the BBC Radio stations problem so far. Getting into the service menu is still a bit hit and miss, but once in, this trick worked and the Tv rebooted itself - Hurrah!
