Problems with software-update at beovision 11
I have bought a cheap beovision 11 with the old software from 2012. But I cannot the software update working, I only says fail.
I have tried:
- update online wireless
- software update via USB with software from B&O
- reset the television
What more to do to try a software-update?
I don’t think there is anything else you can do. The tv should update automatically when powered on. The only conclusion I can draw is that B&O might have stopped the server updates due to the age of the television. Maybe there is nothing more to update anyway? I haven’t checked when mine was last updated but it was a while ago I am sure. I have the 11-46.
I’m pretty sure the last update was to add the internet radio option and that was a good few years ago tho later than 2012 definitely..(I seem to recall late 2017 but nothing thereafter). And that internet radio has now stopped broadcasting the bbc radio stations as the bbc have withdrawn that option in favour of the bbc sounds app as far as I am aware. There have been discussions on here about the bbc issue.
Yes I know the difference of the software. It is not why I made this question.
What I am asking is how can I make it besides from the options I have listed up at the start. See my first post.
What to do besides from the USB and wireless update?
I have tried with a usb with software from B&O, do not work. Can I somehow use a service menu?
Try Ethernet instead of wireless. Some of my older devices only update over Ethernet.
I will try that, when I have found a 20 meter ethernet cable and taken it along the stairs and so on :-)
Easy enough to find on eBay.
Other alternatives:
- use an airport express to wirelessly connect to your router, then Ethernet between the BV11 and Airport Express.
- Powerline transmitter & receiver. Connect transmitter to router and BV11 to receiver via Ethernet.
Many ways to skin a cat
Also, is this a Beovision 11 with a Beo4 remote, or a BV 11 with a Beoremote One?
The Beo4 would have used an older MasterLink chassis, and therefore my guess is that there were no other updates as they moved to the new NetworkLink chassis, where I think the Avant’s last software (NL) update was 2019, which was then superseded by the Android platform which is now superseded by the LG platform
was there ever a ML version of the BV11??
We bought one really early and it was our first NL tv.
And this BV11 came with a Beo4. Later on one could switch sw wise to a BR1.
