Problems with connecting Beocom 6000 handset to base
Hi Keith,
The language of the handsets is Danish. Software version and country type is 045-2.10 0003091514
Well, something is not making sense here, so lets recap on the situation.
- You have three Beocom 6000's, the original works fine with any of your bases, but the two recently purchased Beocom 6000's do not register with any base.
- The "Type" number of the two purchased Beocom 6000's is 0188, so what is the "Type" number of the Beocom 6000 which does work ?
- All the handsets use Danish language and have country code 045
- All handsets have been de-registered from the base, but only the original will re-register with the base
- The software version of all the handsets is 2.10 with the latest version being 2.50
- The two purchased handsets show NOT REGISTERED on the screen.
Is everything correct above and has the working Beocom 6000 been de-registered from the base and then re-registered again ?
Also, de-register the working Beocom 6000 and try and register one of the purchase units again.
1) Correct
2) "Type" number of the Beocom 6000 that works is also 0188 - the same as the two purchased Beocom 6000's
3) Correct
4) Correct
5) Correct
6) Correct
I have tried to de-register the working Beocom 6000 from the base, and re-register it again, and it works without problems.
Well, based on your answers I would say that the RF chips in both purchased and failing Beocom 6000's are faulty. You may have been sold them because they were faulty.
If you wish to get these two handsets repaired or updated to Mark II's then please send me a PM
