Problems with connecting Beocom 6000 handset to base
I have problems connecting two used Beocom 6000 handsets to the Beocom 6000 base. I have followed the instructions from the manual, and I can also get a third handset connected. Batteries are OK, and there are space enough on the Beocom 6000 base for additional handsets (only 1 phone is connected at the moment).
Any ideas what is wrong? I can't find anything on the internet, which relates to the above.
I really hope that some of you can help me.
Many thanks - Thomas
A very warm welcome to your first posting on Beoworld Thomas.
You say you have three Beocom 6000's of which two are used, so I am assuming you have recently purchased them ?
What version Beocom 6000's do you have ?
A Mark I will have a DOT button at the 9'o clock position next to the dial and a Mark II will have the letters INT which do you have and are they all the same ?
Hi Keith,
Yes - I have just purchased the two used Beocom 6000's. All the handsets are Mark I. I do also have two Beocom 6000 bases - and I can't connect the two used Beocom 6000's handsets to any of the bases.
Are you sure that you have not purchased US versions of the Beocom 6000 ?
To check, remove the battery and note the 4 digit "type" number on the label.
I'm having problems with my set-up too. See my earlier post from today. Not sure if these problems are related!
I'll report back if I can finally get my 3rd handset registered.
Cheers,
John
Have you checked that they are not already registered to another base? If so you may have to remove them using the handset menus before registering them to your existing base.
Chris.
Hi Keith,
I'm 100% sure it's not US versions. 4 digit numer is 0188. I'm 100% sure they are danish (which I need)
Hi Chris,
They are not registered to another base. Under the menu I can see, that no other bases are registered.
Hi John,
As I can understand, you have problems with the PIN-code on the handsets. There are not PIN-codes registered on my handsets, so I don't think that we have the same problem.
Cheers,
Thomas
