I have an Avant 32 linked to an Avant 28 in my bedroom and a Beolink Active with a Samsung TV in the kitchen.
RF Modulator is set to on on the 32 and the picture in the kitchen is fine and stable
Picture on the 28 in my bedroom breaks up significantly in the first 5 minutes - as if it's out of tune and then settles down and is clear - any ideas why it would do this when it doesn't in the kitchen - both TV's a fed through a booster and ihave disconnected the aerial to eliminate that as a source of interference. As I'm typing this I've realised that the 28 used to be in the living room so will checl that the modulator is not set to on, but any other ideas if this doesn't work? It's as if there's interference from another chanel but I have changed the link frequency and still get the same result. With the aerial connected the same happens but not on terrestrial channels so I have ruled out that it can be the tuner in the 28
Any help much appreicated.
