Problem with Beovision 3
I have a 28" Beovision 3 I have not put it on for a couple of weeks.Instead of asking for the "Code" which we have in the same place ie top middle the word  "WAIT" comes up for a few minutes then it turns the TV off. Any advise!
It's because there bin used a wrong pin code 3 times. you have to wait 3 h with the TV in standby.
The vendor should have given this to you....if bought used. In case you got a from a dealer, it might not have been set or activated.
If it was not activated/set you can set it in the service menu, Beo 4: Menu, Setup, 0, 0, GO (as far as I remember).
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
It was bought new and I don't have any PIN. Thanks Ralf for your information, much appreciated.
Early BV3 do not have pin code.
I have a BeoVision 3.  Went to turn on yesterday and we can't get it past stanby.  The control works ok as the settings appear in control window still.  This is really frustrating because you can't switch it on manually either!  Please help.
Its possible that it has developed a fault and wont come out of standby to avoid further damage to the set.  Where are you based ... someone on beoworld may be able to help.
Neil
