problem with beolink 7000 and beomaster 7000
Thanks  Andy !! ...YOU ARE A TREASURE!!!
Of course I'll let you know tomorrow evening. What am I supposed to see on my mobile's camera? Should I take a snapshot??? Are the leds visible simply looking at the camera? I have a Nokia, a Sony-Ericsson and a Motorola mobile... Which one , you think is more sensitive?
Warmest greetings from sunny Greece.
George
No you don't need to take a picture, I doubt if you would be quick enough anyway, it's only a quick flash!
It shows up much better on a mobile camera than it does on a digital camera.
Just try looking at the end of your Beo4 or Beolink 1000 when you press anything, it will give you a supprise!
Dear Andy,
 Sorry for my late reply.. Doing that test with the mobile camera i realised that all four lights light up when pressing the panel on Beolink 7000. now , do think that the fault could be with the remote itself???
Contacting with our local B&O service I didn't get any clear answers....to my problem! Is it possible for someone to discover the solution to my problem?
 thanks for your valuable time and advice!
George
Hi George. You can rule out the Beomaster if the four LEDs are showing.
I guess that the problem is the Beolink 7000. If it is the capacitors, that is beyond my field of knowledge.
I am sure I remember reading somewhere that one of our members had to remove all components a few times before it actually connected with them. I think it was Peter. You could try removing them again.
