Problem with beocenter 9500
Hello,
I have been given a beocenter 9500, which has never been used, and is still in it's original box, with instructions etc.
I plug it in, and it says CODE, I've read a bit round here, and found out about putting a code in via the handset, but this didn't work.
coming back to the forum, people mentioned looking for a pin to short, found this, shorted it, but still nothing.
After a while of saying code, this dissapears, and all the lights come on, but the tape & cd deck have opened, and will not close.
Any ideas, or do I need to take this into a dealer to get them to fix it, and if I do, any idea how much it will cost me?
thanks
Kevin
The on board Li battery is goosed and code is how the machine notifies you. There is a FAQ on this subject.
Once the battery has been replace then the numeric sequence must be entered and the unit will then work as normal.
I suggest that you take it to a service technician as some batteries that I have seen have been soldered in!
Cannot take more than an hour plus the cost of the battery!
Ah,
I had a feeling it was something like this. Any idea where the battery is on a 9500, if it's a simple battery swap I could do this (if it's soldered in, then I'll take it in)
thanks
You need to open the unit up. BEWARE LOOSE GLASS...........AND WEAK BONNET STAY HINGE!!!
With the rear of the unit towards you, the battery is at the left hand end of the microprocessor board, outside the metal can on a sort of stick out finger.
Good Luck!
