Problem in beogram 4002
Hello everyone
It is a pleasure to belong to the group BEOWORL from today!
Forgive my poor expression, writing from Spain and my English is very poor.
I have a problem with a BeoGram 4002 type: 5503,
The light / bulb tangential arm does not work and the arm of the needle does not drop.
If that were not related.
All other functions of advance and retreat work correctly.
My question is:
I can change the light / lamp arm tangential?
What are the values of this light / bulb?
Once changed, and lowered the arm of needle?
Cordially
Beolit
Had a quick look in the service manual which was completely unhelpful. I am sure Martin can tell us!
Hi peter
who is Martin?
How can i contact him?
Hi Beolit and welcome to Beoworld !  🤒
I have suitable lamps but I cannot tell you if replacing the lamp alone will make the Beogram play again. The lamp is an essential part of the whole system and you really cannot diagnose any further before a new lamp has been mounted. Replacing the lamp is not the easiest task but if you have basic soldering skills and electronic tools, you can do it.
Hello
that's right, I have knowledge of electronics in order to make him change it myself.
That type of lamp is, how can I get it?
Thanks Martin
