If you place BV7-55 on a wall bracket any speaker can be used....including BL10
If you want a stand with BL10 you need to work with STB Brackets solutions.....
Is it true that for the BV 7-55 there will be also a standing solution with a lift system as an expensive option like for the BV 4-103?
anyone an idea when it will be possible to make a preorder for the BV 7-55 or the BV 10?
Does somebody know who designed the new BeoVision 10?
Mr Lewis I presume!
