Prices for the new BV10-40 and BV7-55 !
It arrives before Christmas, and can be ordered in November says B & O right now.
And the BV10 uses EDGE LED panel lightening for a stunning picture!
So with the contrast glass, maybe even better picture than BV7 ?!
Why do B&O still stick with 40 inch? A BV10-40 is way too small to give you cinema feeling, they should produce a BV10-46 or BV10-52.
A larger BV-10 will be introduced a later...
Agreed, bigger version are welcome. For me a 40 inch BV10 would be sufficient, though.
What I can't understand is why they not uses array backlight🤔
Why they do not use LOCAL DIMMING array backlighting is because the screen is only 4 cm thin and 6 cm with wall mount.
Local dimming needs more space to fit.
And Doc.  It will have a better PQ than BV7 until BV7's go LED and when it does that, nobody knows..
BV7-55 are most likely going to use Local dimming for a even higher and more précised contrast.
regards
Strange as it may seem Schatoy, perhaps not everyone wants their lounge to be converted into a cinema! I may be in minority, but I watch very few DVDs and want my TV to blend in and not dominate the room. I have seen some setups that frankly look ridiculous. If you have the lounge space OK, but I've stepped in to some rooms and the TV practically meets you at the door!
I think it is a case sometimes of bigger, bigger, bigger. Your desire for a 46 or 52 would have been considered totally over the top not so long ago. Next year, 70" 80", just because it can be done? And yes I am aware of the 103" model.
As the TV become thinner, larger screen do not seem so overpowering.
p.
If you have seen Panasonic future tv on youtube, the wall size = screen size.
