The company that sold these doesn't seem to have any in stock. Any suggestions?
Pre-amp for Beogram 4000
What exactly are you after? It was only the 6000 and some later tangentials that had phono preamps. The 4000 never had that option.
I guess he is looking for a suitable RIAA. You can get one from a number of sources - Have a search on eBay or approach one of the re-sellers. About £50 will get you something perfectly decent - you can spend whatever you want though - the cheapest are about £12 - the most expensive £000s!
