Powerlink up to what length?
Hi everybody
Anybody knows up to what length you can use Powerlink Cables without having distortion or noise you can hear?
Perhaps a silly question but i haven't found the answer in the faq or older posts.
All suggestions are very appreciated.
Best regards
David
The longest pre-terminated Powerlink cable made is 20 meters(66 feets). Do you need a cable longer than that?
Joe
Hi
Yes, thinking about 30 to 35 m.
best regards
David
My experience with one run of two 20M Powerlink cables a few years ago was that the sound was a little " noisy " at first.
I moved two appliances nearby ( a television and an SSB radio ) and that did not solve the sound quality. We have much electronics around here. I then ran hard silicone conduit with the Powerlinks inside, and that solved the problem for the moment.
Along came Master-link, and that changed everything. One M-L run only, shorter mains/electrical powerlink connections close to each amplified speaker, with the result of much better sound being produced, including N.MUSIC and N.RADIO Internet sources.
Hi
Thanks for all the information.
best regards
David
