Please help with moving Question: Will my stereo work elsewhere?
I know many of you don't live in Italy but I figured I would ask the question before I talk to my B&O dealer. I have a Beosound 9000 and I am moving to Italy for a couple years from the United States. Will the stereo work in Italy and if not, what will I need to make sure it works?
I don't want to bring it all the way to Italy if I can't use it. Any help is appreciated.
European electrical systems are 220v so your US spec equipment will need a step down transformer to enable it to function in Italy.
I don´t think the radio will work. Different frequencies.
I heard the story about the radio too when I moved with my BS2300 from Germany to US. In the end it worked even RDS.
 It is correct though that frequencies are a bit different.
I Remember you speakers  sent you a PM - however the above has said the same!! Remember the speakers if US will need the same in most cases and these use a lot more power!
The radio will work in Italy just fine. Slightly different FM range but not sufficient to cause major problems.
Quoted Before: European electrical systems are 220v so your US spec equipment will need a step down transformer to enable it to function in Italy.
What is a step down transformer? Approximately how much does htis cost?
For some reason, I thought that the step up converter is in the American cord. I thought you only needed the European cord. Is this correct?
