Please help: Masterlink Gateway - Dimmer and Lighting Controls / Home automation system
After having used the MLGW for a while otgehter with IHC, what are your thoughts now? What are you most happy with and what could improve? Is there some features that you recommend? How often do you use the Beolink app?
Hi!
Did any of you got the message below? The VIS projects are identically. any thoughs why I gets this problem?
2011-09-01 23:24:10 warn server: IHC lost all subscriptions; IHC has been reset or VIS project in controller and MLGW are different. Retrying in 5s.
