PLEASE HELP!!!
"The setup will work. It is important to set the BV to V.OPT 0. Try an additional Powerlibk cable between BM and 1611."I've tried it, but unfortunately it does not change anything.
Sorry, I meant "The setup will work. It is important to Set the BV to V.OPT 0. It will detect the status of the audiosystem. After programming disconnect the 1611 and the BV from the mains. Reconnect some minutes later - 1st BV 2nd converter ",
When you quote me, please do it correctly...
V.OPT 0 won't detect the status of the audiosystem, and I never wrote that.
Please reread my post.
I don't know what's going wrong here, but maybe it is easier to connect the BLs to your BV.
Set them to the correct type of speakers in the BV connections menu, and you will have beautiful sound.
Stefan
Sorry Stefan, I just wanted to say that still is not working.
However, I  have decided to connect the Pentas to BV, everything seems easier.
Thank you all for your cooperation.
Orfeo
