Playmaker Questions
Thank you Stan, I will try that. If it works, it should work indepently of the source attached to the BS 9000.but I believe it can be worked around by pressing A.TAPE instead.
Did you solve question A, and do you hear music when streaming to playmaker and having bs9000 on a.aux?
I have exactly the same setup, and this should work. When you hear nothing I suspect you have the wrong cable.
Playmaker does not respond to a.aux, it just has the preference of Line In against streaming. Playmaker does not respond to remote at all when you have option 0 enabled on it.
Did you fix the outputlevel of playmaker as explained? If not, maybe the output level is zero?
