Hi KMA,
Thanks for posting those pictures and for your additional thoughts on the setup. I wasn't even aware of this combination deal until I saw your thread and the pictures of the boxed package really out some substance to it. It's possible that this may finally be the motivator that gets me into a pair of BL3s. I will say, while I don't like the design aesthetic of the PlayMaker, seeing it in this combination really makes me think that if they just offered it in black in addition to white, I'd likely find it a lot less ugly.
I do have a couple of questions though:
1 - I assume that the combo package comes with all cabling necessary to connect the PM to the BL3s, but what is that setup like? Is it newer cable connections with appropriate adapters or is there an additional accessory box in between (to feed power and audio signal to the BL3s Power Link input)? If you happen to have pictures of that to make things easier to understand, that would be great. I'm just trying to get a picture in my head of how it all interconnects and how much I would have to or want to hide away.
2 - AirPlay control gives you volume, but you can also control the PM volume via a Beo4/5/6. So how do those 2 interact? Does adjusting volume via the latter change the volume slider on the former? Or, are they 2 totally separate volume controls?
Thanks for the help!
Jeff
Hi Jeff,
It would be indeed cool if the PlayMaker would be available in black also; this is something I initially thought when I learnt about PlayMaker, and that it only comes in white.
About your questions:
1) All cabling is neatly packed in the box below the PlayMaker: you lift the PlayMaker out of the package, and all cables & manuals are beneath. There are 3 power cables (2 x 2,5m for BeoLab 3s and 1 x 1,8m for PlayMaker) and 2 new "RJ45 to PowerLink" speaker cables (5m each). These are much thicker than the old PowerLink Mk III cables. Connecting everything together is as easy as just plugging in the cables. No adapters or such are needed: the combo package has everything you need (also including the rubber stands for BeoLab 3 as standard). I actually took a photo of it all while unpacking (yeah, a little nuts, I know):
2) Using Beo5/Beo4 or PlayMaker's "volume wheel" is 2-way when using AirPlay: adjusting volume with Beo5/Beo4 or from the PlayMaker adjusts the volume on an iDevice: the volume slider moves on the iDevice. Moreover, Beo5/Beo4 allows finer steps of volume adjustments: I'd say that 3 clicks on the remote corresponds to one step in the iDevices volume slider. I quite like this, as the steps in an iDevice are quite big increments in actual volume.
Also, of course changing track via remote (previous / next) relates to the iDevice in realtime.
Hope this helps!
