Playmaker and Masterlink - again
mjmedlo wrote:
Can't you just press volume up in those active rooms and trigger a.aux?
Didn't try that; once I knew that A.TAPE does the job I was happy with it.
I believe volume up will turns on whatever source was last used... or if you're pressing volume up on the Beo4, whatever it was last set to.
I'm using a PM through BS4.
To trigger A.AUX I simply turn on the BS4/PM and then volume up in the bl 3500 room and voila.
