hi,
i have been told that the SD card in BS4 can only be used to play back tracks that have been recorded to it from CD using the BS4 and not from MP3 that are currently stored on my PC.
If true whats the point of the card reader then?
hi,
cheers, what kbps is the lowest that should be used before deterioration of quality in bs4 and the bl3s?
whats best mp3 or wma?
MP3, 8 kbps to max. of 320 kbps.
WMA, 5 kbps to max. of 192 kbps.32, 64, 128, 256, 512 Mbyte, 1 and 2 Gbyte SD/MMCTracks must be placed in foldersthe SD card mustn't be the high speed type(100x)
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
