anybody out there using PS as a DVD player, controlled by PUC? Tempting with 8-40 (blue ray + Full HD).
Thanks again.
Thanks again.
Doesn't the rocket launch-sounding cooling fan bother you? I could not handle the PS as a DVD player
I don't get that at all - it's silent here! I have the PS3 20GB version. Perhaps the older models had a louder fan? I'm sure I read that somewhere. The new models aren't noisy at all. Completely the opposite. Never heard the fan. Mind you, I do hear the fan on the Sky HD box.
yes i was at a friends house and couldn't believe he could just sit there and listen to (maybe not a rocket launch) but mini vacuum whirring away, i was trying to cry in the sad parts of a movie and just couldn;t do it with that noise!! 😂
Wouldn't know about the noise since I've never seen a PS except boxed in.
Assuming that noise is not a problem, is it convenient to use (as a DVD player)?
I think the fan noise applies to the old original models.
Well, you just put the DVD in the drive and use either the controller or a bluetooth remote to control. Yeah, easy.
PS3 is an excellent bit of kit, upscaling standard DVD's and outputting 1080p via blu-ray discs - I hardly play any games on mine, highly recommended.
When playing blu-rays, the fan doesn't seem to be very loud at all. I think it gets noisier when using other features eg streaming media, looking at photos etc.
Here it works almost perfect with a STB-C controller (table 4.01 and 4.11)
You have to buy a Nyko infrared dongle to convert the ir-signals from the PUC/STB-C to the USB port.
You only have to switch on the ps3 manually on the ps or with the standard remote (ps button)
I've been using a PS3 at LifeStyle and home for ages now! Upscales normal DVD's beautfully, plays Blu-Ray and brilliant games perfectly - and have never given me a moments trouble!
I'd recommend highly!
Lee
