Play station 3 with Beosystem 2 and Beo4
Can someone just confirm for me that the Nyko Bluwave Blue tooth to IR dongle is the correct one to use to get the Beo4 working via a Beosystem 2 (STB-C has PS3 in the list) to control a PS3.
Can't believe there is nobody out there with a PS3 connected to a B&O TV ?
If you have one connected can you tell me the IR / Blutooth dongle you are using and if it's good or not ?
Previous threads seem to indicate the NYKO device is OK (can accept no turn on or off)
Anybody !
If you seek forum you will find many answer🤒
and as you answer your own guestion: "Previous threads seem to indicate the NYKO device is OK (can accept no turn on or off)"
Thats right!!
If you will turn on your PS3 you need Schmartz to. You can turn off in SMB.
And it works good
