Hi guys,
I wonder if anyone could help me here. But how would I be able to delete the pin on a set of BeoLab 5's? I've got the pincode and everything, just don't know how to delet it!!!
Cheers,
Jimbo
Hi guys,
Cheers,
Jimbo
Hi Jimbo
The Deactivation instructions are on page 15 of the Lab 5 instruction booklet at the end of the "Use the pin code system" section. There are 6 paragraphs of instructions and are a bit long and involved for me to Type.Could I suggest that you download the user guide from the main B & O website ?
In order to deactivate the PIN code system you must first key in your previously chosen four-digit code, and then key in the ‘0000-code’, which disables the function.
While BeoLab 5 is in standby…
If it is not accepted the loudspeaker emits a sound signal, and you will have to start over again with the ‘0000 code’.
