Pin code beoLab 5's
Hi guys,
I wonder if anyone could help me here. But how would I be able to delete the pin on a set of BeoLab 5's? I've got the pincode and everything, just don't know how to delet it!!!
 Cheers,
Jimbo
Hi Jimbo
The Deactivation instructions are on page 15 of the Lab 5 instruction booklet at the end of the "Use the pin code system" section. There are 6 paragraphs of instructions and are a bit long and involved for me to Type.Could I suggest that you download the user guide from the main B & O website ?
In order to deactivate the PIN code system you must first key in your previously chosen four-digit code, and then key in the ‘0000-code’, which disables the function.
While BeoLab 5 is in standby…
  • Press ss, ss, and STOP in quick succession on the Beo4 remote control. The indicator light shines intermittently red (1 sec.) and green (0.5 sec.).
  • Within 10 seconds, press the touch field on top of the loudspeaker you wish to deactivate. The loudspeaker confirms your selection with a sound signal.
  • Key in a your previously chosen four-digit PIN code*. The loudspeaker confirms each digit with a sound signal.
  • Press GO to enter your four-digit code. The loudspeaker confirms this with a sound signal.
  • Key in the digits 0 0 0 0 on the Beo4 remote control*.
  • Press GO to deactivate the PIN code system. The indicator light shines red again – indicating that the loudspeaker is in standby and ready for use.
If it is not accepted the loudspeaker emits a sound signal, and you will have to start over again with the ‘0000 code’.
Cheers thanks Keith....
