Picture mute on BV 10-40 beo4
redil wrote:
Regarding the adjustment, Vienna would you have a pointer to the above mentioned documenation
WB4667 Adjustment Plates.pdf attached
@Vienna: thanks a lot, now I see how that is supposed to work. The plates are gone with the installation folks.... but this can indeed be anything.
Thanks again
redil wrote:
While we are at it and with lots of seemingly knowledgable folks around: the panel is somewhat slanted forward: top is 3mm further away from the wall than the bottom, (the wall itself in perpendicular) can this be adjusted?
😁 ... seemingly knowledable installers ... spot on
PS: to avoid overcompensation and following the rules of geometry
- you'll need to raise the edge by approx 2/3 of the amount of total misalignment - 2mm in your case
Mine is also mounted very slightly leaning forward. I think that makes sense dependent on how high on the wall it is mounted.
As you can see from the pic, the BV10 is not so high up on the wall.
