Penta base plastic cover...
How is the plastic cover of the very bottom base removed???
We need to clean and polish under them....
thanks,..
Held on with double sided tape I believe. There is every chance that you will destroy the silver if you take them apart!
Thanks Graham...
So, difficult to take apart and clean below???yes??
 we've got dirt underneath....the plastic...
