Penta 3 Speakers
Hi I have pair of Penta 3 Speakers at home and one of front panel is broken.  I have wraped around them with ceiling flim so that it does not stick out. any one out there knows how to repaire them or even just make don't stick out. I don't have to use control at all. I can stick with same setting!! Please help me.
The two plastic tabs that stop it falling open have both snapped and can only be replaced complete with the door. I am not sure if these are still available from dealers.
Why don't you hold them shut with two blobs of Blu-Tack as a temporary measure? I'm sure it would look better than cling film!
Andy T.
Spring that hold door is too strong!! got any other suggestion please??
Try accessing the spring and unhinge it to release the tension then use the tack tape. It has been awhile since I carefully looked at that area of a penta speaker.
Good luck.
Dave
Open the flap further and remove the spring.
Keep it safe incase you get a new flap in the future.
thank you I have done it and it was vey helpful.
Andy T.
