If you have time and passion for restoration/upgrading, then you can go ahead with the Pentas.
They are my main speaker in my audio room, having Lab 3 and 8000s in other rooms, and the only thing that sounds limited compared to the new BeoLabs is the treble , that lacks some presence. This, and other things, can be easily overcome .
I did some serious restoration on mine, reconing the midrange drivers with rubber surrounds, soldering the internal wires with silver , replacing all caps, renovating the frets with new fabric, reversing the mid-treble enclosure on one of them to have proper symmetry, and the most recent upgrade was to pair them with a DSP that works like BeoLab 5's ABC, meaning the bass response is equalized to compensate for room acoustics.
I'm happy to tell you that the 100/120 Hz issue that Peter refered to is now gone, and that the Pentas, rated at 40 Hz at -8dB , are now producing 30 Hz at -6 dB without any problem!
I also saw the Visaton midrange replacements on another british website recently, but never tried them.
