Hi guys...
On the...on the PCB 24 on the penta II....the P114 goes up to the jumper and on to P113-6 audio/video switch..
Which 2 legs is this jumper supposed to be between....???
THe displays are not working as of yet....
thanks !!!
Hi guys...
thanks !!!
Frank,
Do you mean J2 which is between P113 pin 5 and R26 ?
P114 does not go to a jumper, but it goes directly to P113 pin 6
ahh....just to the right of that on page 2-3...the P114 from R47 up to P113-6...
I beleive is the one in question...there are 3 legs down...and the tech tells me that there is a jumper between 2 of the legs...
thanks Keith !!
Below is the circuit you are looking at
