Pc2 and iPad2
Karla wrote:
elephant wrote:
Karla wrote:
rxcohen wrote:
Correct - the ipad communicates wirelessly to the AE. From the AE you need a cable that goes from the headphone jack on the EA to the BS9000 AUX jack. If you go to a B&O store they should have one. Sounds Heavenly who has an advert on this site also seems to have one which looks a lot nicer than the one I bought from B&O.
Then on the BEO4 remote you use the A-TAPE to turn on the BS9000 and start streaming data from the IPAD.
Genius! Pure Genius!  Thank you very much. I will let you know when we get this accomplished.
But if you already have the ATV2 working on the Avant, then from the room with the BS9000 in it try calling up the Avant AV to which you have the ATV2 attached ... and then from an App called Remote (free of charge) on your iPad you can access your iTunes library and use Airplay to send the sound track to the ATV2 through the Avant along the Masterlink and into the BS9000 and its attached speakers !
You are correct and that is what we do, but if someone is watching the Avant with the AV2 then you cannont stream music at the same time. Last night we watch Netflix via ATV2 and my son wanted to stream the iPad2 through the BS9000, and it could not be done via the ATV2 while we were using it.
Very true ... and $129 for family harmony is one hunderd and twenty nine well spent dollars 😂
You saved my day!! I was using this solution with an Airport Express and a BS3000 but found out that A.AUX doesn't work via the remote (although the Beo4 can add it). It is of course very clumsy to start AUX manually on the BS3000 and then go to my BL2000 and start it also manually. But A.TAPE works also so at last I can effortlessly listen to my iPad's music library!!
Bart
Glad to help - I have been using this for many years (since the laser on my BS9000 is broken) and it works very nicely. I only wish the airport had a better DAC, and would also not occasionally lose the connection (but alas I dream)
