PC + Beolab 4 + Beolab 2 subwoofer - how to connect Beolab 2 ?
I wonder if anybody would be able to help me on how to effectively connect a Beolab 2 subwoofer into a PC + Beolab 4 (Non-PC version) set-up ?
It would be interesting to see what you might come-up with - I've tried several methods but, although the Beolab 4s work perfectly, the Beolab 2 remains on stand-by and doesn't activate.
Easiest solution: get a BeoPort & connect the Lab 2 to the BeoPort Powerlink output, then each BeoLab 4 to BeoLab 2!😁
Thanks ... appreciate the quick reply ... that sounds like a quick, easy option ! I'll set-it up and let you know howit goes ...
How does it sound? Isn't the Beolab 2 Sub an overkill for BeoLab 4 speakerS?
I replaced my BeoLink PC2 (old Version) with a BeoPort. It now works (nearly) perfectly with the beolab 4 and beolab 2.
The sound is really cool and it looks perfect with my home office.
However, When I just hibernate my pc the speakers are still on. so i first have to exit beoport and than hibernate my pc.
I want to get a BeoLab 3500 soon ..
