Hi All,
I am about to link my 3 Avants and would appreciate some advice.
All three are essentially in a line, ie living room Avant - (15ft) - Bedroom 1 Avant - (10ft) - Bedroom 2 Avant.
I have a DVD1 and Virgin V+ box attached to the living room Avant which I'd like to be able to control / see in the other rooms. I would also like to receive the roof aerial signal in the two bedrooms (currently the roof aerial connection is in the living room only)
My question is therefore whether I should go with the passthrough option so I would be running one RF cable from living room to bedroom 1, then 1 RF cable from bedroom 1 to bedroom 2.
Or
Should I go with an amp, meaning I would be running two RF cables from the living room, one terminating in bedroom 1 and the other in bedroom 2. If so, can anyone recommend one since my dealer tells me theres no need to go with the B&O version?
The advantages with the first choice are obvious - less cabling, easier to install, cheaper (no need for an amp). I'm sure the later option would give a better result but it would have to be significantly better to warrant the extra effort.
Your thoughts would be appreciated as always!
