I have real trouble to get the BD35 to work, unfortunately I am unable to locate the IR receiver to control the player with my BS3 & PUC. Any idea where it is?
Karsten
Karsten
It's on the right hand side of the disk tray, but to the left of the lettering. I think it's *just* to the left of the first logo on the top.
FWIW, I've found the 'Generic Panasonic Blu-Ray option works fine in the PUC controller.
Alex, great thank you! Now it works. Unfortunately I have only the PUC for the Panasonic DMP-BD10 which works great execept power off function.
Do you have any problems with power Off or On with your PUC?
Karsten
I can't say I've ever tried powering down the BD35 through the PUC controller. TBH, it's not something I'd worry about, although it's something you might. The last time I checked (which was a few weeks ago), the BD35 wasn't on the PUC controller list, so a software update from your dealer would do nothing.
I'll try and find out if anything is happening for you!
Great, thank you very much!
(power on works with PUC, just checked this)
