Painting Beolit panels - see the results!
I seem to remember a thread on this, but can't seem to find it (maybe lost on the old forum)
Has anyone done this and can they give me some idiot proof guidance of how to do it in terms of cleaning, prep, what type of paint, lacquer etc.
I want to acheive as close as possible to the original B&O black. Currently they're the most disgustiing shade of "mustard that's been left with the lid off"!
Cheers
Nigel
I would be interested also - I have a mustard Beolit 707 that is faded - I had thought of Metlic Purple or Blue would be different.
Well I have a spare red cover that has a hole drilled into the side by a previous owner so he could fit a thumbwheel to tune it after the string brokeErm
One of you is welcome to have it for free to test the results. Just PM me an address & I'll pop it in the post.
However, I personally wouldn't want to buy a painted Beolit so only do it if you intend to keep it. You could always ebay it and buy another in the colour of you choice or buy a broken/tatty one with good panels then swap the panels over and resell again.
Incidently the FM only model's side panels won't fit the AM/MW/FM models
Steve
Hi Steve
I've sent you a pm with my address - many thanks
Cheers
Nigel
Hi Nigel, If you want I will see what i can do for you as I work in a car paintshop!!  if you want me to take that panel when you get it and I will see what i can do, and we can go from there!  Cheers Nick
What you need is Nextel paint - as used by a well known Danish manufacturer on some models.
Hi Nick
Help couldn't get much closer than that! Sounds great. As soon as I get the panel I'll drop you a pm.
Need some bodywork doing on my 18year pld BMW too!
Cheers
Nigel
h1npw wrote:
Hi Nick
Cheers
Nigel
No problem, let me know when it arrives!!
It went off 1st class today
And thanks to good old Royal Mail, it dropped through my letterbox this morning. Many thanks Steve.
Nick, I'll drop you a pm with my phone number.
Cheers
Nigel
