Overture and airport expess
I would like to play my music via airport express through my old overture I know I can play it through the overture but I have two passive kits is it just a case of pressing a aux on the link rooms then using my iPhone to select the music!!
Kai
Yes.
You may want to place an external DAC between the Airport Express and the Ouverture to improve sound quality. In that way you use the digital output from Airport Express, eliminating its internal DAC which is quite mediocre.
Sigmund
