Ouverture with Beolab 2500 wont work!! HELP!
Blackrix wrote:
No matter in what option the BeoSound Ouverture is programmed, it should always work using the keyboard on the Ouverture itself. Sometimes a key on the keyboard gets stuck between the surrounding metal on the keyboard, keeping the key pressed. But in that case the doors also will not close, because when a key is pushed the Ouverture won't close the doors to  protect the fingers of the user. It could also be a problem in the Ouverture.
pressed all the buttons to check for sticking all seem OK, should i take the front panel off and check the connections?
Was it sold as working? Did you see it work when you picked it up? I suggest that maybe that was why it was in storage?
Hi Peter, it was sold as seen, he did tell me that it was working fine upto going into storage but when he brought it out, it wouldn't play anything. I was hoping it was a simple fix but as I only paid £200 (including the Beolabs) its a worthwhile punt!! I've turned it off now to see if that will help... Anyone got any other ideas?? Do the control panels go faulty?
certainly worth a punt a £200!  Even if you have to spend a bit on it!
I have to say Beoworld I'm a bit disapointed with the poor response to my post, there was a time when answers or solutions where 10 a penny!! Is there a new site no ones telling about?
I think you got the right answers in a very short time, but sometimes there just is not a ready to go answer. It seems like the problem is in your Ouverture, but it could be the keyboard, the processor, the power-supply or maybe something else. It could be that the Ouverture was struck by lightning, who knows?
You could try to disconnect the keyboard from the display PCB and see if it will work on remote. Make sure the Ouverture is in option 1, not option 0, or else the remote won't work.
