Hi Beoworld hope all you guys are well.
I've just bought an Ouverture with Beolab 2500 but when I've got it home and set up I cant get the thing to work!!
The red light is on,
the doors open,
the cd clamp opens and close but wont spin or play CDs,
No radio or tape functions at all
The display wont turn on apart from the red light
If you press cd, tape, radio or aux the door just close
If I use my Beo4 nothing happens apart from the red light flashes once
Its almost in a standby mode or something anybody got any ideas?
Is there a reset button?
