Ouverture with Beolab 2500 wont work!! HELP!
Hi Beoworld hope all you guys are well.
I've just bought an Ouverture with Beolab 2500 but when I've got it home and set up I cant get the thing to work!!
The red light is on,
the doors open,
the cd clamp opens and close but wont spin or play CDs,
No radio or tape functions at all
The display wont turn on apart from the red light
If you press cd, tape, radio or aux the door just close
If I use my Beo4 nothing happens apart from the red light flashes once
Its almost in a standby mode or something anybody got any ideas?
Is there a reset button?
probably an option problem, you will have toreset it bl1000
press standbyand sound together
then press 1
then press storeshould work then I had a similar problem
if it doesn't the try above with either 0 or 2 one of which will work
sorry cannot remember the correct option mode but it is one of the above
!salut
tony
Hi thanks for the reply,
do i do this using the beo4 or on the Ouverture because i dont have any buttons saying standby or sound?
Haaaaaa!!!!!!!!!
Don't know how to do it with a beo4 but yes its remote base
try pressing list until optin appears press go scroll thro to audio press go press0 1 or 2then go - i think thats it otherwise do a search on the site for option setting
I always use my bl 1000 as its dead simple!
t
now found my book, it goes
hold standby buttonwhilst pressing list, scvroll to options press go
press list until a optthen hkey 1
should then be fine
t
Cant get that to work!! any other options?
hold standby button whilst pressing list - ie at same time - , scvroll to options    press go
press list until a opt  then key 1
try pressing   go
should then be fine
sorry about the mistakes etc my keyboard is on it way out and i cannot get a qwerty kybd in france they us ethe quaint old azerty`layout
t
HI thanks for the help but it doesn't work! it must be another problem with the thing!!
Wouldn't hurt to unplug it and leave it unplugged for several hours.
No matter in what option the BeoSound Ouverture is programmed, it should always work using the keyboard on the Ouverture itself. Sometimes a key on the keyboard gets stuck between the surrounding metal on the keyboard, keeping the key pressed. But in that case the doors also will not close, because when a key is pushed the Ouverture won't close the doors to  protect the fingers of the user. It could also be a problem in the Ouverture.
According to the chap I bought it from, the Ouverture as been in storage for the last 2 years and not used. Could this be the problem? ie damp?
