Optical into BS3 with sky Q
Have you changed the spdif setting in the BS3 for the socket you use?
I know this a novice question, pardon me. Do I need a converter if I wish to connect LG tv optic output to bs3 spdif input for better sound quality or is there a magical cable that can be connected directly from LG optical to bs3 spdif ?
Yes. Selected the audio via spdif
Appreciate the info
