Opinions of the Beovision 8-32...
elephant wrote:
If you are also getting a beo4 and a stand I would say that sounds fair.
You might also want to configure as a monitor for your guests - I find it very useful as a monitor.
And we configured ours for attaching various game controllers !
I may have more questions about this if I end up getting it!   My plan is to have a Roku connected and maybe a game console.
Tucker wrote:
However, I found what seems to be a good deal on a Beovision 8-32 with an adjustable wall mount...
I used to like my 8-32 (which I owned before the 10-32 and was then replaced with a 11-40) in the kitchen.
Only snag is, I found it hard to clean as it was like cleaning a basic LCD panel. No glass, no protection, nothing.
Well, I got the BV, Beo 4, and wall mount for $275.  I think that I should be good at that price.  I am looking forward to its arrival and giving it a test run! 🙂
Master123456789 wrote:
And ENJOY - I love this television. :) :) :)  So bad they don't do it in a 2017 updated version with all the new stuff. But it have hdmi, so you can add on almost anything. The sound is very good also.
Indeed I would buy a Beo8-40 with a Beosystem4-like inside (like the Beoplay V1) in a heartbeat.
 Master123456789:
__________
yep, but that is more expensive! :) and I also miss it in white.
Well the BV8-32 came today!  Unfortunately it does not have the MasterLink connection that I thought it had.  It says "MasterLink" on the back, but there is no plug.  Is this something I could add easily?  Also the "soft touch" finish is a bit beat up.  Has anyone attempted to remove the coating or repaint it?
