Hi Egon,
I like to connect the bs 9000 to core by power link, the Beogram to core by line in, and 2 bl9 to core
it will work?
Hi Egon,
it will work?
This means: BS9000 Powerlink (out) to line-in of the Core. This said: the line-in of the Core is occupied and not available for a Beogram anymore.I like to connect the bs 9000 to core by power link
In Egon's post it is not clear how he solved this. But let him surprise us! Or did he connected the Core to the BS9000? Or does he using a kind of line-in switch? Or..............
If the DPl input of the core works as and aux port maybe you could connect it …I don’t know , my dealer told me to do it the core and the beogram to a switch and this to the 9000 , but I would prefer it the other way .
DPI?If the DPl input of the core works as and aux port maybe you could connect it …I don’t know , my dealer told me to do it the core and the beogram to a switch and this to the 9000 , but I would prefer it the other way .Thanks
Connections of the Core: 1 x USB-C (for power via external power supply),1 x Power Link socket (RJ45) with two channels, 1 x Line-in (analogue & digital combo) with sensing, 1 x Ethernet 10/100 Mbit/s, 1 x Toslink digital sound out, 1 x USB (for Connection to the BeoSound Shape).
So only one IN possible. But the solution is obvious: Connect a Beogram to the AUX of the BS9000. Powerlink connect the BS9000 to Line-in of the Core.
Note: the remote control of the system wouldn't be simple.
DPL sorry, it’s the digital power link I guess ,
I thought That the only sound that you can get from the digital out of the 9000 it’s from the CD player so maybe you can not get the audio from the Beogram ?
Yes, that is the reason why Carolpa writes the line-in of the Core…..meaning the analog input port.
(That would work - not considering the somewhat clumsy volume/remote controlling).
DPL is - or rather was supposed to be - a digital powerlink output.
This has never been realized on the Core - the port is used for connecting an ir-eye nowadays, if that should be needed.
