Open CD tray with remote?
Dillen wrote:
Apart from the technical challenge, am I the only one wondering about the practical use of such a function?
I mean, you will have to go to the player to load or change discs anyways, - or am I missing something?
I recall a thread on this forum years ago about the interest especially with a BeoGram CD 4500 to reduce fingerprints and excessive touching of the touch-control panel.
Oh..
And the OP has a non-working keyboard on his Beocenter 2500.
Makes sense now... perhaps. ❓
I had the same problem with my Beocenter  ouverture, had to replace the keypad.
works great now.
K. Parker
Hi Keith where did you find the replacement keyboard?
Sorry, it was the membrane behind the keypad, this is the place I bought it from. It takes a bit of time and a sharp chisel.
K. Parker
A bit of help perhaps..  All the codes are here:
link
I believe that load command is actually the EJECT command 0x2D
I am 100% sure you could do this with the AV terminal, which by by far is the most versatile of the IR remotes. A lot of the deeper, cool functions was unfortunately lost in the BEO4 implementation, although the codes still exist!
I've found some surprising codes available when programming a Beo5/Beo6. Maybe looking for the EJECT command there could show some Beo4 equivalent button combination.
Any idea of the key sequence?  I presume you have to use the SHIFT or CONTROL button?  Can it be done with the BL5000?
I found the EJECT command in the Beo5/6 configuration and created a button for it. It works! I tried it on my BeoSound 2300 and my BeoGram CD 4500 and it opens the door and/or clamper.
The Beo5/6 configuration tool only showed the command as "EJECT." It did not show any alternate command name.
I am playing with it right now 🙂
I remember opening and closing the tray on the CD player  in the 5500 system using the AV remote, I dont know about the BL5000 though!
There was a lot of easter eggs in that remote. One I vividly remember was the ability to use wildcards in text tv. *** would simply show the entire set  of pages flashing by as they were decoded, quite fascinating, and doing it on someone else's TV always made people panic... 🙂
I will let you know if i succeed.
