OneRemote HDMI switch for BeoVisions
Hi all,
Do any of you have any experience with OneRemote HDMI switch for B&O tv?
I would love some more HDMI inputs for my BeoVision 8-40 and came across this solution from OneRemote. Both the Gefen and Atlona options are way to expensive to me for a few more HDMI's. This one is way cheaper, but does it work?
http://shop.oneremote.dk/catalog/product_info.php?cPath=31_33&products_id=3299&language=en&osCsid=bc7q2q75vela10j9o7gg3q2vb4
hi ,i use the marmitek hdmi switch  costs 35 euro,s and works perfect
grt cvb
Hi karlquist and thank you for your answer.
Which PUC is used to control the switch? :-)
My question too :)
Their website says "Operate your connected A/V equipment remotely via the infrared return signal" - I hope this means remote Beo 4 controls ?
I'm googling like crazy for different solutions... and though it is more expensive than OneRemote, Marmitek and a ton of other brands, then I'm enchanted by the Atlona AT-HD4-V42... Would be great with two outputs - maybe I should add a projector? ;-)
But if I add a switch with PUC control, I will be loosing an IR input on the television and only have 3 left for my 4 HDMI inputs? Correct?
The problem in general about adding HDMI-inputs is that you soon run out of PUC's - and there is no PUC-extender!
Yes there is a way to extend PUC control :)
http://www.bang-olufsen.com/en/picture/beo6?gclid=CIHy9vDypboCFSXItAodQRkAIw
......a pretty expensive one 💰
I'm so glad for your responses.
f I add the Atlona switch with 4 inputs and 2 outputs, will I then have 4 or 5 HDMI's available on my TV?
The switch will be added to HDMI B, which gives the inputs B1, B2, B3 and B4. But is HDMI A still in action or will it be unavailable, when I add the switch?
