Same with me as well😮Everytime I try to read this thread on the app it keeps crashing, is this a coincidence???
One month with the Moment
yes, me too, long for the IOS app.
I do not agree with you . You should be able to embeeded the Album covert (Artist Art) into the audio file in this case you swill be independant from
Gracenote or any other similar stuff.
I agree with you, that it would be good to add be able to att artist art.
I was just explaining how it works today 🙂
I think they should do it like this:
- if artist art is not available on Gracenote and album/song is stored on local server retrieve artist picture from local folder if available (not sure if Twonky supports this)
Dear BeoSound Moment Fellows,
just for your information. 2 days ago Apple rolled out his latest OS X - El Capitan. Therfore I was "forced" to do a "real-world"-test on my dedicated BeoServer (mac mini) solely used with the BeoSound Moment.
If anyone is hesitating because the danger to destroy the fragile, long groomed perfect setup of his own, I can assure you - everything is fine without a new factory-reset and without a complete new hour-taking processing of your DLNA-Content on the BS-Moment
El Capitan is working perfectly with Twonky 8.1.2 and the BeoSound Moment 😁
Here is a short manual, how I did the update from Yosemite with Twonky 8.1.2 to El Capitan with Twonky 8.1.2
Before I started I did a complete backup. - I learnt it in the hard way, that Apple can mess up a new OS X too. "Yosemite" is known as Apple´s "VISTA"
- I switched the BS Moment and the NL/ML Converter off.
- stop the Twonky Server 8.1.2 on the mac
- close all Apps
- install El Capitan
- check for new updates in the App-Store (iTunes, Safari...), install them
- after the Installation, everything should be perfect - the Twonky-Server 8.1.2 is fully compatible to El-Capitan.
- when the Twonky-Server has finished the rescan after the last restart, check your content on the Twonky-Server
- everything is fine? Yeah! Switch on the BS Moment and the NL/ML Converter
- now your BS Moment should show your Twonky-content like with yosemite before.
- if your content is missing, check under "devices" (settings/sharing/devices) that your BS Moment is shown and connected to the Twonky-Server
- make sure that you choose the "Bang & Olufsen"-device for your BS Moment and the "mobile" Navigation Tree (settings/sharing/devices)
- do a Pin-reset on the Soundheart and the Jukebox for apr. 15 seconds
- Now you should see your content, without any need for a complete new day-eating processing of your database
Done! Have fun!
Cheers Beroli
Thanks Beroli, I was already showing symptoms of anxiety and panic.
Beroli - is the "mobile" navigation tree a must ? Twonky recommends Advanced Media Navigation for large libraries so I wonder what to select with 31k tracks?- make sure that you choose the "Bang & Olufsen"-device for your BS Moment and the "mobile" Navigation Tree (settings/sharing/devices)
El Capitan is superb, saying that, I found Yosemite to be absolutely fantastic in everyday and rock solid! Even running on an old 5 year old MacBook, it was flawless.
then I am happy for you. A lot of users had trouble with Wifi (because of Applesworld-wide-field-test of their own wifi-standard) mail-, printer-, graphic-issues, endless beachball-issues, some features like Hand-off never worked properly ... . You should be lucky, that you had an older device, some of the troublemakers were deactivated by default. ... But this is a B&O-Forum. i just wanted to "ease" the "never change a running system"-fraction of us. ;-)
Cheers
Hi
I have just switch to a Moment since 3 weeks. Have anyone found a way to get gapless playback on the Moment?
Hi
