The Moment was recently made available in the US and I am considering one. However I am somewhat confused about how it would work with my system and have some questions. I hope someone does not mind answering them.
I have a BV7-55 with attached speakers and a BV10-40 with attached speakers. They are connected with Masterlink along with a Beosound 5. There is another Masterlink connection available in a third room which is where my router is I also have a stand alone Beoplay V1.
My questions are:
1. Do I need one or two NetLink converters to be able to access the Moment through the BV7/speakers and BV10/speakers?
2. Does/do the converter(s) need to be connected to the BVs, or if only one is needed, could I connect it to the Masterlink in the third room?
3. Once the Moment is connected, if I wish to listen to music, must I turn the Moment using the Moment, or can I use the Beo 4 to turn music on as I do with the Beosound 5?
4. Will the Beoplay V1 connect in any manner wirelessly to the Moment or will the two remain completely separate?
5. Any comments on sound quality of Spotify on the Beosound 5 compared to Deezer on the Moment?
6. I have heard that in a couple months Deezer will make Elite available to all Deezer subscribers, not just those with Sonos system. Is this true?
Thank you in advance.
Hi Razlaw,
I try to my best to answer your questions, in short.
1 No, you just need one ML/NL converter to connect thru Masterlink both TV's
2 Yes, you have to connect every ML product thru masterlink
3 Yes, the Moment and converter needs a networklink. Your TV's are connected thru masterlink. The converter has networklink & masterlink input so its all connected with each other
4 if your V1 has the wireless build in to connect to your network, but remember its always better to connect by a cable.
5 I have no experience
6 It could be or not, there are rumours that the exclusivity ends by 2015, so why not for next year?
Chris
