One month with the Moment
Use the BeoRemote app. the Music app does only make sense if you have some NL products e.g. moment, a9mk2. You will not have many features with a v1 and the BeoMusic app (I think you can only regulate the vol).
Skiingtrumpeter wrote:
A fair point. Might you have time to list the remedies or solutions to the Twonky, Tagging, DNLA and network stability issues that have worked for you?
No need to list things up. You will find a lot of good info in this thread on how it worked best for users of the Moment. I do my tagging of files with Yate and are using Twonky 8.0.3, who seems to be running more stable on the new Yosemite than the proposed 7.2.7 version from B&O.
lonfred wrote:
Then I have several Netgear Wndap350 wi-fi access points in my house so that I have full coverage for the Beomusic app
Now we're talking about some serious WiFi access 😐
Software v1.3 to be released early next week...
Nas problems solved?
Good news, any idea about the release notes.
I do not know all the details, but v1.3 is said to solve more than 40 reported issues - including:
  • Jukebox and SoundHeart loosing the connection.
  • Music stops playing after a while
  • Several attempts required to update the sw
  • Unable to submit error log
  • No Deezer images in search results
  • Volume control lags
  • Fast forward skips
  • Album art "moving" / vibrates
  • Alu and wood wheel not responding
  • Empty TuneIn folder shown under Radio
  • "Connecting..." shown on tv when starting Deezer from TV
  • Not all albums from a NAS device shown under Artist
  • Bluetooth improved
  • Special characters not shown correctly in Jukebox
  • Roger
  • Roger
    A very welcome update. The child is growing up very fast now, at B&O they are really doing their best.
    Patternplay isn't working any more on my Moment. Instead it only starts playing the latest song I was playing the night before, when I'm pressing the middle button on the wood side of the moment. Does anybody has the same issue?
    I know it sounds like a famous sitcom (Have you tried to switch it off and on again?). I experienced that the most recent issues I faced, went away after I did a Pin-Reset on the Soundheart and the Jukebox as well - about 15 seconds on each Device. Place the Jukebox on the Soundheart again, after! the Soundheart LED's are constantly green and white. Sadly this helps in the most cases - it is not satisfying - but until there are no bugfixes on the horizon....
    ... and it will not harm your existing database.
    Cheers Beroli
